Oilers
ranchdadmike
5:21 AM
AL
I have a 371xp that was ported a couple years ago by tlandrum at wicked work saws. It's a fantastic saw and my go to. My issue is the oiler. I run a 24 almost all of the time and recently it hasn't been oiling up to snuff. I could just replace or repair the oiler as usual, but while I'm at it I wondered if there is a higher output option that factory because I do occasionally run a 28. Any advice?
mdavlee
Hillbilly grinder
5:21 AM
TN
Those usually do fine with a 32-36". Check and make sure the pickup isn't clogged or the oiler drive is stripped
Jimmy in NC
5:21 AM
North Carolina
Also make sure the oil hole in the bar is clear. I normally open mine up a touch and make sure to keep the groove clean.
