WANTED OEM 064 Cylinder
Trader history (4)
jacktheripper
Papa Squat
1:18 AM
Wyoming
That makes me feel better, but I still wonder... My 266 and 5105 are super high compression, even at this altitude. I know people can get tripped up on compression numbers, and maybe I've just proven myself to be one of them I suppose.
farminkarman
I like the red & black ones
2:18 AM
Neenah Wisconsin
If you want to set that 064 free, send it to @srcarr52 Here is the dyno sheet for one he did:
Woodwackr
1:18 AM
ID
Not worn. It's a new Meteor. Very little slop when in the cylinder.
B or C cyl ? Meteors are all Bs unless you specifically order an A. At least that’s in my limited experience.
Shave the cyl base for better squish?
jacktheripper
Papa Squat
1:18 AM
Wyoming
I'll have more info on this soon
Powerstroke Cowboy
1:18 AM
Montana
Dynos are a great comparison tool. If all parameters are the same you get to see a good before and after idea. Both numbers might be off since it depends on the information entered. But, if both are tested the same way with the same data you get to see your gain, or loss. Dynos are a great tool.
srcarr52
3:18 AM
Iowa City
Both of those saws have pretty high cranking compression to begin with.
Here for the Yum Yum Sauce
2:18 AM
While not common, it is possible, especially for older well used saws, for the cylinder to have some ever so slight warping to it. This will take some time for your rings to fully shape to. As long as you're saw is making enough to start and run, keep running it, one day it will surprise you.
I actually had one this summer that was so bad it wouldn't start with new piston and rings the compression was so low and had to be replaced. This being on an old loggers saw, with lots of use.
jacktheripper
Papa Squat
1:18 AM
Wyoming
So I tore it down again today - finally got around to it. It is a Mahle B cylinder running a Meteor B piston with Caber F cast rings that have about three tanks on them. Ring end gap measures .013"+. Plating all looks good.
I also have the original Mahle piston on the shelf, which wore through almost all of the machining marks on it but still fits fairly tight in the bore. The original rings on it were at .015" end gap.
Maybe throw the Mahle piston back in with a light ball hone job in the cylinder and new set of regular Caber rings, and then just run the piss out of it to get rings to seat?
jacktheripper
Papa Squat
1:18 AM
Wyoming
I have a set of Cabers and a set of HL Supply no-name rings coming in the mail. I'll see how the ring end gap is, maybe one has a smaller gap than the other.
