WANTED OEM 064 Cylinder
Trader history (2)
jacktheripper
Papa Squat
5:19 PM
Wyoming
I think my cylinder might be worn out. New rings, .027 squish, only 140psi.
Let me know if you have one.
Nutball
6:19 PM
Mt. Juliet, TN
Is the plating worn through? Can you resize some over bore rings?
jacktheripper
Papa Squat
5:19 PM
Wyoming
Plating isn't worn as far as I can tell. I was thinking about finding some bigger rings and filing the gap. Does anyone have a suggestion on a set of rings for it? Oversize 52x1.2mm I guess?
Nutball
6:19 PM
Mt. Juliet, TN
I assume 140psi is low for what your particular gauge normally measures on most saws, right? I found 150 and 165psi for a stock 064.
jacktheripper
Papa Squat
5:19 PM
Wyoming
Same gauge was reading 190psi on my 5105 and 195 on my 266. I just haven't had this issue with long break in with Cabers before, but you may be right. Unfortunately I didn't measure end gap, just ball honed the cylinder a couple of passes and threw em in there. I do take into account that I'm up at 5800 ft, so 140 would be more like 160 up here
farminkarman
I like the red & black ones
6:19 PM
Neenah Wisconsin
I have had some Cabers take even more (like 15+ tanks ) to notice break-in. I would consider 150psi to be normal for that after break-in and I’m at 850’.
7:19 PM
Any jug pics?
Agree with all of the above. Caber F-cast take even longer to break in.
jacktheripper
Papa Squat
5:19 PM
Wyoming
Any jug pics?
I'll tear it down and take some sometime soon. Maybe I'll just run it and see what happens after a few more tanks too
Woodwackr
5:19 PM
ID
Is this one of mine? I should still have pics
srcarr52
7:19 PM
Iowa City
How worn is the piston?
