Mathewsdxt75
Learning OPE member.
- 10:52 PM
- Feb 25, 2016
- wisconsin
I figured I would share what I was wondering about the nova modules and what I found out.
I have my old Echo 302s that wasn't running good at all. I had it pin pointed to an ignition issue. So instead of replacing points and condensor, I chose to install a nova module. After install, I had spark so I completely reassembled saw and it fired right up.
But I was curious with how close the timing would be. Understanding that it triggers off where the flywheel is as rotates past the coil. I decided to check the timing. This particular saw has marks on the flywheel and case to time the saw. I verified that the one mark is exactly at TDC and the next mark is at 30 degrees per saws spec on timing.
So with a timing light in hand, I spun the saw over with the fastest drill I have. And behold, the timing is at 33 degrees BTDC. Now I know.
So for anyone wondering if the the nova modules time ok. On this particular saw, it is spot on.
