- 10:33 AM
- Feb 5, 2016
- grafton wv
evening silver eagle hows you
Drum wore?As far as I can tell everything is original Stihl chain and Bar fits on the spur right it revs up make zero chain movement
I'm good buddy. Just put another pot of coffee on.evening silver eagle hows you
No sprockomite, hard tipbar sprocket froze ?
No. It's like clutch won't engage or somthinDrum wore?
Friction material on the clutch worn out?No. It's like clutch won't engage or somthin
Bfh....loosen that bish upNo. It's like clutch won't engage or somthin
Looks all thereFriction material on the clutch worn out?
Here yah go DallasWhat if you engage and disengage the brake
can you engage the brake and get pictureHere yah go Dallas![]()
Yes but I gave up an sittin in me chair now[emoji39]can you engage the brake and get picture
I did that an at that point the clutch is engaged an spinning@leadfarmer Run it with the cover, bar and chain off to try and see what is going on, or not going on.
