- 1:40 AM
- Feb 5, 2016
- grafton wv
Evening mike how's you
Good evening Dallas, what are you up to?Evening mark how's you
I'm doing great, how about yourself?Evening mike how's you
Lt50 Mike?Not much, got a cool little 2 stroke 50 quad to work on for my boss.
Bingo, good evening DJ, how are you doing?Lt50 Mike?
What's the issue? If it won't start and seems down on compression check the flywheel side seal before you do anything. They tend to pop out.Bingo, good evening DJ, how are you doing?
im telling carrieI like bingo to find dates
It's been sitting for about 6 years. I got it running pretty good, but the boss wants me to go over every nut and bolt. It's for his nephew that just turned 5. He will probably have me do a few mods before it's all done I'm sure.What's the issue? If it won't start and seems down on compression check the flywheel side seal before you do anything. They tend to pop out.
What saw ya working on DJ?Doing a little squish sanding...![]()
They're corked up pretty good. Pop the restrictors out of the intake and exhaust.It's been sitting for about 6 years. I got it running pretty good, but the boss wants me to go over every nut and bolt. It's for his nephew that just turned 5. He will probably have me do a few mods before it's all done I'm sure.
372 xtorq. Had Shaun cut the base and squish have to adjust it a few thousandths to get it perfect.What saw ya working on DJ?
I did the intake, but not the exhaust. I need to call around and see if I can get some jets to play with.They're corked up pretty good. Pop the restrictors out of the intake and exhaust.
afternoon gary hows you
Nice so those 2 saws will be done soon then. I'm curious to hear how they compare to your 371.372 xtorq. Had Shaun cut the base and squish have to adjust it a few thousandths to get it perfect.
