Status
Not open for further replies.
Sty57
3:30 PM
Land of Cheese & Beer
Sup bishes. I'm full of sweet corn. .....and chit
hoskvarna
3:30 PM
Iowa
You should NOT need a new flywheel. Has to fire in the same place whether points or a module are doing the job. If you convert to a modern Stihl modulated coil then you MAY have to change the flywheel. Not with the NOVA II. You say you have spark, but do you have good spark? By this I mean will it jump an air gap of say 5mm and be a bright blue color and snap right across? If not the problem is most likely a weakened coil. One other thing make sure the ground from the module is being grounded out at the coil, not somewhere else on the motor.
Yes it has good spark.
I will have to check on the ground ,cant say for sure on that.
Thanks for the help.
Wont work on it now for a couple days ,got some other things pressing.
Status
