GCJenks204
"Special Buns"
12:25 PM
Winnipeg, MB
Well guys, I need your help if you can spare some.
Lydia is the daughter of one of my staff and she is epileptic, she has had a couple brain surgeries to try and fix it but they have been unsuccessful so far. Yesterday they travelled to Toronto and tomorrow she will be going under the knife again, and this time it is not a laser that they are going to cut with but an actual knife.
If you could spare some positive energy, or if you pray please send some Lydia's way. She and her family deserve some good luck and a positive outcome.
Tor R
Novice, Leg model #2
7:25 PM
Mandal
I wish Lydia a successful surgery, and that what they are doing helps her have fewer and weaker seizures.
They call me Mr. Kibbs
1:25 PM
Wandering the VA woods
Prayers sent, and +1 on Tor's sentiment
AlfA01
8:25 PM
Evia, Greece
It’s rare that I’m envious of other climbers because I know the work involved in the pictures. But damn Dan that’s an experience of a lifetime bro!
Morning men…. and pothole.
Thanks Brad! It is a ton of work with restricted access, but worth it to spend some time at one of the most well known archaeological sites.
cuinrearview
Handy dood
1:25 PM
Dowling, MI
Done
Wonkydonkey
Plastic member
6:25 PM
Sussex, UK.
What all it it bolted to?
The 6mm winch plate which is bolted to the chassis. Here’s a few pics I tookwhile doing it. If I had a bit more time I would have added another bolt to each side of the chassis . Which I will probably do some time soon just for peace of mind.. as it is a big winch for the plate . you see the square hole in the chassis in pic 1 and in pic 2 it’s just a bolt 12.9 with a washer. In that sq hole 🤷‍♂️. That’s why I really want to drill another hole and add another bolt. However the winch bolts supplied to fix it to the plate are m10 12.9 x4 … so if I do the maffs I think it’s ok with the other bolts as it is
Anyway It had to be drivable at the end of the day. And all the faff of fitting the bumper and it not fitting then the cutting the inner bumper bit by bit till it fitted took more time than i thought.
I wired it up today to a solenoid /rely, I just put a switch to it to be sure it worked , then I fitted the dash switch and had the joys of routing the wiring 😩. Anyways the dash switch works to power the winch now. Which looks professional 👍
ray benson
12:25 PM
nw indiana
Prayers sent
ray benson
12:25 PM
nw indiana
beaglebriar
The Peanut Gallery
1:25 PM
Warren Center, PA
Prayers up for the kid.
12:25 PM
That's sounds rough, hopefully there's lots of positive vibes going her way. 🙏
