JoeDirt
Piss Jug Tosser
5:29 AM
United States
Was it because he didn’t have a CDL?
You gotta have a CDL if you are over 26,000. You've gotta have a CDL-A if you are over 26000 AND your trailer is over 10,000. If the trailer is less than 10,000 but the combo is over 26k, you need a CDL-B with combinations restriction removed.
stihl livin
Do the Dallas
4:29 AM
Upper Midwest
Is this nation wide?
Loony661
462’s 4-LIFE
4:29 AM
Winona County, MN
I understand all of that. That’s why I was asking Randy if his friend had his CDL…
LAWN BOY
Pothole
2:29 AM
Merrill, WI
Dall hates Ford's
Your granny hates Ford's
You hate Ford's.
You loves Chevy's
Dall loves Chevy's
Granny loves Chevy's
Need I say more, or should I rest my case.
Mostly true, except I don’t HATE Fords, us and people we know have had bad luck with a lot of Fords except for the 7.3 diesel, we have one, my grandpa has one, we know several other folks with them, those are great motors.
5:29 AM
i run 25000 pound license on both trucks i could go to 26000 without cdl
they also go by tire ratings
so if you have single wheel truck and 10 ply tires which is about 3000 pounds per tire and 2 axles on trailer with same tires gives you 18000 total on those 3 axles that doesnt count your steering tires
so if you add another 6000 for front axle max is 24000
dually axle tires are rated about 2800 for the dual axle
then i also run 14 ply tires on the gooseneck which is 4000 per tire so you have 6000 front axle
2800 times 4 for rear axle of truck and then
16000 on trailer so at 25000 pound license im still ok
same thing with tractor trailer that is rated at 80000 license unless you get licensed more or permit
but still have to be below tire per axle ratings or adjust the load to set more or less on the truck
