12:48 PM
12:48 PM
If Joe doesn't want it, I'll text you some pics of it tonight to see if it's something he thinks he could use.
He'd probably be better off using something with common flanges. He's working on setting the ECM up to be tune-able now.
redline4
I'm huge in Japan
12:48 PM
Rosholt Wisconsin
the one that sucks is the right front wheel line
or atleast you havent told ,me the secret for them
Best I can tell you is install them in this order..
Rear line.
Right front to EBCM
Left front to EBCM
Front of master cylinder to EBCM
Rear of master cylinder to EBCM
If you install the rf line through the front, over the steering gear, through harnesses, then along inside of frame and kind of work back and forth pushing it through, it's not the worst.
redline4
I'm huge in Japan
12:48 PM
Rosholt Wisconsin
If my memory is correct the only thing that's not a flange is the connection that would go to the charge air cooler. And I'd imagine that hose could be pulled from a wrecked Equinox/Terrain at a yard for not much $$.
1:48 PM
Rear line.
Right front to EBCM
Left front to EBCM
View attachment 389772View attachment 389773View attachment 389774
ive done the yukon and the blue truck so far
USMC615
Fapper Fi
1:48 PM
Mid-Georgia
Damn slackers.
Ewe tell ‘em Munkee.
And it’s raining like a mofo here, hailed pretty good earlier…of course the bottom fell out about 5 mins before quitting time and there were some soaking wet asses by the time most these folks found da parking lot. Having sense enuff to look at the weather first thing in the morning and a simple umbrella will usually cure that problem...usually.
