redline4
I'm huge in Japan
8:06 AM
Rosholt Wisconsin
Personally, I'm a big fan of the tin foil.
Right?
You can use it to keep your leftovers fresh.
You can use it on your rabbit ears to get in channels never thought possible.
You can use it to make a pimp grille to mimic some rappers.
You can use it to keep your mind from being probed.
You can even wrap taters and onions up in that and toss it on the actual grill.
Most people dont know there little tabs on the ends of the box you supposed to punch in so they keep the roll from flopping out of the box when pulling out sheets too.
maulhead
7:06 AM
Home
Right?
In the 80's my brother & I would put pieces of tinfoil on our teeth, then run around saying, metal mouth, metal mouth. It used to piss our one sister off something bad, she had braces.
Mom used to wrap those plate shaped things on her stove top with tinfoil.
8:06 AM
timg
9:06 AM
Keystone State West
Agent Smith
Hack of all trades
9:06 AM
Northeast ohio
Garlic is doing well. 2nd coated walls today. Patched holes in the concrete from the carpet tack strips. Stained an oak door and will urethane tomorrow. Said fug it and came home. Did some more garden bed prep. Planted more seed taters in the new raised bed garden. Now its Heineken 30 and sit down time
