farminkarman
I like the red & black ones
3:16 PM
Neenah Wisconsin
Morning fellars
Just got home
They found nothing. Lab tests all negative ct scan nothing
They think a intestinal virus [emoji3083]
Gave him 3 doses of pain meds before he got relief
He was hurting so bad he was in fetal position and crying at 20yrs old
He’s tuff so he was bad shape
I’ve been up for 24hrs now so its nighty night for me [emoji42]
Sent from Hoskey hilltop
If it happens again, ask them to check for gall bladder stones....I had to have my gall bladder removed when I was 20.
farminkarman
3:16 PM
Neenah Wisconsin
Any of you fellers use Loctite 518? What's the cure time on that stuff for a cylinder base?
Dan, I don’t recall what the cure time is for that…should say on the tube. I have used it on two builds…one worked and is still working. The other started leaking after the first time I cut wood with it. After that, I switched to Dirko.
AlfA01
10:16 PM
Evia, Greece
The tube doesn't say much. It has the instructions for use, but nothing about the cure time.
I'm told the secret to a good seal with 518 is cleaning the surfaces. First time I've used it so I'm curious to see what happens.
Dream
4:16 PM
Elberton, GA
Interesting fact on the 6.7 Ford diesel is the integrated exhaust ports to the cylinder heads and no manifolds was designed by GM.
The General in his infinite wisdom decided to sell that to Ford rather than use it on its own engines.
Great, something else expensive thats gonna break...:)
Hows it going Ed?
