Saw Collector
OPE Member
3:40 PM
Here
The OME kits were hot when I did mine so that and the small pucks to fit 33s and the engine/Trans mount adjustments for vibes. It would go anywhere except the mud pits.
I did the 4" Terra Flex long arm, Sway bar disconnects, Currie steering set up and rear adjustable track bar. Slip yoke eliminator with a custom double cardan shaft. Factory trac lock rear, Detroit true track up front. HD axle shafts. Borla cat back exhaust, turbo city adjustable timing sensor, map sensor and a 160° thermostat. Cold air intake. Hard mount Quick Air II compressor. I'm sure I'm forgetting stuff. It was a pretty bad ass rig. I wish I'd kept it.
hoskvarna
2:40 PM
Iowa
All this soft food is getting old really quick
Sent from Hoskey hilltop
Woodpecker
Sassy Madam
3:40 PM
Wonkydonkey
Plastic member
8:40 PM
Sussex, UK.
