- 6:53 AM
- Dec 3, 2015
- Banner Springs Tennessee
Good evening fart blossoms.
If that comment was re what i think it was.....hell yeah! Like seeing a mouse check in on some alley cats.Holey Moley
Surprisingly yes.
Ring end gap is around .050".
Supposed to be from .004-.012".
Still pulled 135 psi on a compression test and ran on a prime into the plug hole.
Plating was gone in several spots in the cylinder. (Ive got a good one for it).
It would have run for no telling how long if id just cleaned the carb and put fuel line etc on it.
Those old bastids will still run hurt.
They turn maybe 14k WOT, and spend most of their time around 10 or a little lower.
Ever seen this in your ope career? I was hot cleaning that Opti 2 test survivor in my repurposed roaster over "hot tank" at 400° in my solution of Super Clean / water. Everything is clean, even the underside of the piston and everything you saw in the cylinder. But that happened in the pic below. Probably the stress from the press fit and the heat. Guess I should have kept it around 300 like I normally do. Or I cracked it blowing it off with the compressor after pulling it out. Guess what, running it anyway till it pops. The top bearing didn't come around anyway. Its burnt black from the testing and does not spin freely. Going to do something stupid with it.Good evening fart blossoms.
I'll have to double check, but I didnt notice that it had locate pins.Is that with the locating pin subtracted?
Ruh roh!Ever seen this in your ope career? I was hot cleaning that Opti 2 test survivor in my repurposed roaster over "hot tank" at 400° in my solution of Super Clean / water. Everything is clean, even the underside of the piston and everything you saw in the cylinder. But that happened in the pic below. Probably the stress from the press fit and the heat. Guess I should have kept it around 300 like I normally do. Or I cracked it blowing it off with the compressor after pulling it out. Guess what, running it anyway till it pops. The top bearing didn't come around anyway. Its burnt black from the testing and does not spin freely. Going to do something stupid with it.
lol I’ll raise you a crank lolEver seen this in your ope career? I was hot cleaning that Opti 2 test survivor in my repurposed roaster over "hot tank" at 400° in my solution of Super Clean / water. Everything is clean, even the underside of the piston and everything you saw in the cylinder. But that happened in the pic below. Probably the stress from the press fit and the heat. Guess I should have kept it around 300 like I normally do. Or I cracked it blowing it off with the compressor after pulling it out. Guess what, running it anyway till it pops. The top bearing didn't come around anyway. Its burnt black from the testing and does not spin freely. Going to do something stupid with it.
it was brought to me saying it had a knocking sound lollol I’ll raise you a crank lol View attachment 302083View attachment 302084View attachment 302085View attachment 302086View attachment 302087
Wasn't that way b4 it went in the cooker. They heated up together, didn't drop room temp parts into the boiling solution.I can't say that I've seen that before.
Plan on it getting clamped wot no shaft. They will scream north of 10,000 easily that way.Ruh roh!
Dat one ees no bueno.
Spin it up to about 15k, maybe less, and it'll scatter.
Ouch. Whats that on?lol I’ll raise you a crank lol View attachment 302083View attachment 302084View attachment 302085View attachment 302086View attachment 302087
Even Brett from Texas might struggle to get that cutting a tree within the hour.lol I’ll raise you a crank lol View attachment 302083View attachment 302084View attachment 302085View attachment 302086View attachment 302087
10 mm 044Ouch. Whats that on?
lol it still ran like that i had it runningEven Brett from Texas might struggle to get that cutting a tree within the hour.
You just need ones that start the way theyre sposeta.You two mfers ↑↑↑ just gave me another big reason to not dislike you. I'll be shaken yer paws we ever meet in person n stuff. There are variables in all our beliefs but this is a very important one to me. Thank you @full chizel fir that link.
Some crazy mfers these days would consider that child abuse. I've read of bills some of these commie bastages are kicking around with hints of this. Not in our state.....yet, but the more commie States.
So a 100 way north of me up in the Canada, 74 here and near 90 by you. What is going on? Its the airplanes I tell ya..the "chemtrails" lol.
We need to talk. I've gotta slim my collection as much as it pains me. Ive found its the rope yanking on cantankerous old saws that really ramps up my neck, shoulder, arm and face pain from my wrecked arse neck.
I call bullshite! Most talented business owning, saw fixing professional cheff we've never met. Have faith. He can steal and claim others pictures like no other.Even Brett from Texas might struggle to get that cutting a tree within the hour.
I have more than mini macs. I'll get with you tomorrow. One saw in particular has around 200 psi and it's a bear. It bums me out.You just need ones that start the way theyre sposeta.
I'm not a big fan off yanking a damn rope til I see spots either.
I WILL NOT BUY ANY MORE MINI MACS.
Dammit, its not working.
Just PM me...
Of course. It ain't no boat anchor or dodge.10 mm 044
