Slumberjack
Team OPE benchwarmer
2:00 PM
Way down south Louisiana
One of those roller guides is a good learning aid. It will help you learn how high the file needs to be. After awhile, you'll be able to do it without the guide.
I think I’m past that stage. I’m able to make one look factory but it’s when I start trying other things to make them faster I go the other way
3:00 PM
for softer woods or faster you want more hook than factory but it is a fine line between fast and junk
Slumberjack
2:00 PM
https://youtube.com/shorts/NBfbooWXZNs?feature=share This is one I hand filed with using the depth guages and keeping factory profile on a basic mods saw. Cuts ok. But all the little tricks people have to make them go faster is what I was trying to figure out and I just go backwards
Lightning Performance
3:00 PM
East of Philly
2 in 1 file guides sucks on new chain and sucks on very worn down cutters. It will sharpen half a tooth or less up to around a third gone just perfect. This is the fine line Dallas speaks of. Too much hook makes a weak cutter on hollow filed round or ground chain. Square suffers much less from these issues. One big reason square severs the fibers easier than round it is a true chisel point cutter. It also has less drag on the side plate by design.
Slumberjack
2:00 PM
Cool I’m paying attention
Slumberjack
2:00 PM
after about 4 chains i throw them away
if i dont see filings they are junked
and cheap files suck even new
I’ve noticed tractor supply files don’t have that feel of the material being removed when you can hear as well the sound
