full chizel
¯\_(ツ)_/¯
- 12:04 PM
- Sep 12, 2019
- USofA
A bear at the zoo doesn’t chit in the woods
But, but, what if dey has a big bear pen and dey is trees n stuffs in it dat makes it LOOK like woods?A bear at the zoo doesn’t chit in the woods
has his own toilet?A bear at the zoo doesn’t chit in the woods
first, make sure the blade is on the arm correctly, with the shark fins facing forward.
next, mix your favorite boat motor oil, 25:1, with old *s-wordty gas.
as soon as you get it started, hold throttle wide open for 2-3 minutes to warm it up. then engage blade to the wood, preferably with a back and forth motion.
This one is for sale, Wayne.
Tie the anchor to the rear end and you will be fine, trust me, boats I can.
It is already in the US, Wayne, but by all means, if you want the "battleship" to be transported back and forth across the pond then I can always ask sawtroll if he is available for a lucrative mission ...That'll work bro.
Can you ship that to me?
Seriously tho, can you borrow a dab of bedliner to check it doesn't eat the foam?If a bear $hits in the woods and nobody is there to see it did it really happen? Hypothetically....
A bear and a rabbit happened to be taking a chit right next to each other one morning and the bear asked the rabbit if chit stuck to his fur, the rabbit said no it did not. So the bear picked up the rabbit and wiped his azz with him.
I be texting you bout the boat anchor tomorrow.Good evening mfers.
They had these old vintage sleds on display at the custom car show todayA bear and a rabbit happened to be taking a chit right next to each other one morning and the bear asked the rabbit if chit stuck to his fur, the rabbit said no it did not. So the bear picked up the rabbit and wiped his azz with him.
You a crazy man Jason.Had a little off and on problem for the last couple of months...upper left tooth farthest back was loose and giving me some crazy ass headaches/borderline migraines on occasion. Too damn hard-headed to go to a dentist, soooo...Dr. Crown Royal and I took a little detour to the shop a little while ago. Cranked up some boiling water on the stove, ‘sterilized’ an offset pair of rubber tipped cannon plug pliers, and did the deed. Dr. Royal shined. It was immediate relief. Immediately clotted, no blood, took four ibuprofen, knocked down a little more Crown, and everything good.
i didnt know you had a boatI be texting you bout the boat anchor tomorrow.
They had these old vintage sleds on display at the custom car show todayView attachment 290914View attachment 290915
Replace them with womenThey didn’t wanna work today. Said they were tired from yesterday
