7:06 AM
Used to have to get a heavy duty flasher for the older trucks if you wanted to pull a trailer. Standard flasher was underpowered for the extra incandescent load of trailer lights and truck.
Most newer vehicles have a heavier flasher already if they have a towing package. Most 1 tons do anyways.
LED lamps DECREASE the load, and the flasher unit flashes faster because it doesnt see ENOUGH load.
The resistor in line between the flasher and the light "fakes" the flasher into seeing a normal load. Resistance to voltage increases current.
Damn shame theres no Radioshack stores left around. You could run down and pick up those resistors cheap and quick.
lol ive used the heavy duty flashers before i thought it was something special
i do have one resistor left from when i put one in so my cruise control would work in yukon because of the led tail lights
ill order another and then worry about it
truck wont be put on the road for another week or so
Dagnabbit @Mastermind , look what you started!
i thought your name was adam
Very sensitive
Did you gey that? I mean get that... lol
lol so pat has softer hands than his wife ?
is that what you are saying for 100% ?lol
Dream
7:06 AM
Elberton, GA
So you gonna put them in parallel or series?:cool:
We could try parallel. That could get interesting.:p
Used to get emergency light bulbs from the mill when we upgraded. My lawn tractor used the same physical size bulb, but the ones from work were 6 volts. Just wired them in series...
Kiwioilboiler
346 Pic Examiner
11:06 PM
Marsden Pt, NZ
I did em parallel. No-one thought it would work. But that's what Ford did so i copied, and it does work, on multiple different trailers and adapters, and even a dummy plug to fool the truck into thinking it has a trailer on when in fact it is only a towball mounted bike rack. I'll try and find a pic for evidence.....
Slumberjack
Team OPE benchwarmer
6:06 AM
Way down south Louisiana
I say parallel. You need more load. Series will make the problem worse
6:06 AM
