Dream
3:27 PM
Elberton, GA
View attachment 276374 Spent all morning tracing wiring in a hot dirty ash handling MCC to find a bad output card in a nice clean air conditioned cabinet failed. Ca de don sa. :facepalm:
Yall still running 5 series, or is that Contrologics?
That probably woulda Been the last place ida checked too...
Too easy.:D
Slumberjack
Team OPE benchwarmer
2:27 PM
Way down south Louisiana
Too easy.:D
We still running rs5000. I’ve not used any control logix. I hear it’s nice. Ya it’s usually not that easy lol
Kiwioilboiler
346 Pic Examiner
7:27 AM
Marsden Pt, NZ
Only thing I've got to say about that is if youda started at the card end then it woulda been a fault at the far, hotter end of the loop. Murphy.
We have Honeywell pixie stuff here. Well, we call it Moneywell because everything seems to require more money to get it to work how we expected it to on commissioning.
Kiwioilboiler
346 Pic Examiner
7:27 AM
Marsden Pt, NZ
Slumberjack
2:27 PM
That dam Murphy! Lol We have Honeywell DCS controlling the Allen bradly for logix managers. On the other unit we have ovation. I love me some ovation!
Kiwioilboiler
346 Pic Examiner
7:27 AM
Marsden Pt, NZ
I'm just a simple panelman (Boardman?). If my graphics go magenta or the change zone won't work I just holla to the Moneywell fulla 30 feet away. White man's magic it is.
Kiwioilboiler
346 Pic Examiner
7:27 AM
Marsden Pt, NZ
What product does your tower produce?
Well....on my panel I have:
3x 45 bar Stork HP Boilers, 2 online, 1 spare, Fuel Gas or Fuel Oil or Asphalt fired or combination of liquid and gas.
The letdown system for steam 45 to 23 to 3.5 bar.
Steam and electric air compressors that provide 6.5bar control, plant and tool air.
A distillation/fractionation column for Heavy Arab crude stock.
A jet fuel desulphuriser.
A Hydrogen Seperation unit.
A diesel desulphuriser.
A triple cooling tower.
A butane vapourizer pair.
And a PC for YouTube and OPE.
41FanForLife
3:27 PM
Don Martin's House
You should have had doc and Marty pick you up some plutonium and get you a new flux capacitor. Hahaha. Just busting balls. Electronics and control setups way beyond my current mental capacity.
Kiwioilboiler
346 Pic Examiner
7:27 AM
Marsden Pt, NZ
Probably not mate. How long did you train to get walls looking true when the surrounds aren't actually square. And spacings right on non even divisible spans etc etc. Given long enough most folks on here I reckon could give most things a pretty good crack. Embracing the suck as you learn is the issue. Plus,....I'm of the opinion a brains only got so much remembering room. Once it's full you have to purge a bit to make some space for new learning.
Slumberjack
2:27 PM
Well I’m pretty terrible at carpenter work I can promise you that! Lol
Slumberjack
2:27 PM
Ah so no gasoline components?
Kiwioilboiler
346 Pic Examiner
7:27 AM
Marsden Pt, NZ
Yep, out of the distillation column.
Naptha, Kero, Light Gas Oil, Heavy Gas Oil and Residue.
Naptha to the Platinum Reformer for gasoline (petrol).
Kero for air planes after it is desulphurised.
LGO and HGO blended for pour and freeze and then desulphurised for diesel. Under 10ppm sulphur here.
Residue for further processing into fuel oil, vacuum cracked gas oil and bitumen and asphalt.
