Saw Collector
OPE Member
3:02 AM
Here
Damn that looks good Steve, except maybe hide the carcasses of the "donors".
I'm a bit behind. Did you get it to oil?
Thanks bud. Only one was a donor of its pump. Yes she oils in the correct area now. Bar instead of the cylinder. The three in back all run. One has 100 psi compression, one 160 and the other 170. That 170 psi unit is a mm30. @Steve gave it to me in the Christmas giving thread. Turns out it's fully rebuilt with just a few tanks on it. New closed 4 port cylinder, piston, rings, seal and gaskets and a carb swap to a betterer carb. All his words not my professional investigation skills.;).
Anyway, I'm taking that motor and putting it in a minty mm120 chassis. I removed the break pivot on the left side. I'm using the clutch side cover off the 30, top handle off the mm 6 ect, ect, ect. Basically all the best and nicest parts on one saw. Probably going to paint it. The rest of the parts are going to coalesce around that 160 psi mm120 powerplant and into the mm30 chassis. The weak but good running mm6 gets the left overs and heads to my cousin. Yeah, a lot of effing around for "just a mini mac" but I enjoy it and they aren't hard to work on for me.
hoskvarna
2:02 AM
Iowa
Morning fellars
Gonna work on bobcat splitter today
Sent from Hoskey hilltop
Slumberjack
Team OPE benchwarmer
2:02 AM
Way down south Louisiana
Good morning OPE, good evening Todd. This morning was supposed to be an easy four hours. A couple checks on a running furnace and prep some stuff for tomorrow. You mfers had ONE job...View attachment 271744So now the day just got longer, and easier. Enjoy your Sunday fellas.
Dam operators :patadaenwevs:
Slumberjack
2:02 AM
Nope. That's my counterpart on 2nd. And the head of maintenance is the last lock off. That's alright, a 6:00 wake up call for a 2nd shifter may help him remember next time.
Ha im surprised they didn’t call em last night. That’s how they do us.
