Read that the Mantis 7920 tiller and the Echo TC210 tiller are very similar, as they use the same Yamabico 21.2cc two-stroke engine, have a 9-inch tilling width, feature a worm gear drive, and weigh approximately 20 pounds. The primary manufacturer of the engine, Yamabico, is the parent company of Echo, which explains the similarities in specifications and performance between the two models.
But I only found an operator's manual.
