Need a ms 210c engine. ..
cobey
5:47 PM
Pittsburg, kansas
I got a neighbors 210c
It needs a piston and cylinder,
I thought a 025 engine fit it
But nothing I find says that
5:47 PM
So what I have found is the the whole motor assembly ( crank and p/c ) will fit. The two motors have a different stroke. If you look on the HLS site they are all grouped together. I have a 021 that is going to get an AM 025 complete motor dropped in one of these days.
cobey
5:47 PM
Pittsburg, kansas
The only thing is it doesn't list it on the part just 023 and 025, I never went threw
A 210 so I didn't know if it would work.
I didn't want to work on this turd butt........
You know how it goes
5:47 PM
From what I have read the 021 is 40x28 mm 023 40x32mm and 025 is 42 or 42.5 by 32mm
That's why the 023 and 025 are grouped together.
I was told a complete 025 will be a perfect drop in.
cobey
5:47 PM
Pittsburg, kansas
I might do that..... I just don't want extra
Parts I won't use
Lightning Performance
6:47 PM
East of Philly
Had no clue about the stroke difference. Put a 210 in my dads hands years ago. He loves it. Said it screams. I was told it has a stamped cheap con rod.
6:47 PM
East of Philly
Psst... get a 250 block if your going to keep it ;) :pesas:
cobey
5:47 PM
Pittsburg, kansas
I forgot Chad had told me this before,
I try to find out sure deals before getting
Parts.... I do put a few am parts
On 290 type stuff
5:47 PM
Just read the other post. It makes sense now. Just like a 200 or 201 bottom wif a cheapy crank and rod.
Speaking of cheap cranks them Troy bilt string trimmers have the cheapest crank I have ever seen. It was like 3 pieces of stamped metal spot welded together lol.
cobey
5:47 PM
Pittsburg, kansas
Speaking of cheap cranks them blown troy bilt string trimmers have the cheapest crank I have ever seen. It was like 3 pieces of stamped metal spot welded together lol.
There are 2 blown up troy built
Weed eaters in the junk Shed
