FOUND IT Need a 262XP Cylinder
Eagle1899
5:44 AM
Central Minnesota
Looking for a good used OEM 262XP cylinder.
Picked up non runner with a straight gassed Star GRY cylinder. Looking to go back to factory jug with a Meteor piston and Caber ring.
Thanks for looking, let me know what got!
smokey7
5:44 AM
Detroit
Is star gry the brand of aftermarket set on it now? I am curious of the timing numbers? I have a jonsered 625 case with new bearings and seals i have thought about trying to fit a 262 jug on it. So if the 262 jug could be used for at minimum mocking it up or decent enough to run for a little bit i could possibly use it. Let me know what shape its in thank you.
Eagle1899
5:44 AM
Central Minnesota
Smokey7,
Star gry is the one I pulled off. If I can get a oem jug for my 262 I'll send you the star gry. I am going to clean up the aluminum transfer using the Mastermind method for now. I am pulling the rest of the saw apart this week to do the bearings, seal, etc.....
1Pitbullman
Active OPE Member
2:44 AM
In Da Woods
Smokey7,
What IS a star gry?
