Is there enough room for the chain to rotate if this is clamped to a bar? I wonder is it is used to hold a long bar off of a work surface so you can sharpen a chain and with it around and without having to list the bar each time you rotate to the next link?
Mystery solved. @heimannm identified it on AS; it's a bar clamp from a Comet diesel, and I had three Comets when I was living in Italy, all sourced from Sweden. If I recall correctly, one of the saws came with a spare clamp so I kept it in case I ended up with a Comet that was missing the clamp.
It is a "stump vice" and they are supposed to have a spike on the bottom of the "U" to stick it in a stump and them clamp the bar in the vice while you file the chain.
