My MS360 update
GlocknStihl
Derelict OPE Member
1:10 AM
At God's feet
I took my 360 back apart because I wasnt happy with it.
So I started with the Hyway cylinder. I cleaned up the transfers, and the other ports. I widened the exhaust port .020" and lowered the intake port .010" to give a little more intake duration. No base gasket, and squish is .018". Also took .025" off the flywheel key to advance timing.
Its idling at 2800-2900 rpm, and it four strokes at 14,000-14,300 rpm. It's never ran this strong. I took it out and dropped a large pine, and an oak. Very pleased with this saw now.
Probably boring to most of you, but I'm very happy with the outcome.
20180725_114903-1612x907_crop_804x315.jpg 20180720_194435-1612x907_crop_760x280.jpg
NPKenny
10:10 PM
Lehi, AZ
What did you start with? Any previous port work on the Hyway cylinder? Muffler mod?
GlocknStihl
Derelict OPE Member
1:10 AM
At God's feet
No it was all stock. Turned out it had a leaking base gasket, I knew the power didnt feel right. I just decided to try for a little more. Now it runs better than it did when I first got it.
1:10 AM
You being happy with it is what it’s all about. Good job.
Have you learned how to use a timing wheel? What were the numbers on the saw?
Oem Jugs usually don’t need any intake floor lowering.
GlocknStihl
Derelict OPE Member
1:10 AM
At God's feet
No timing wheel on this one. Just mainly cleaned it up to get it running better.
