Ms462 base gasket delete
TX_Welder
11:35 AM
SE Texas
Anybody done a base gasket delete on a 462 ? Checked the squish on mine and its .038 right now. Thinking about doing a delete, timing advance and a muffler mod.
BonScott46
6:35 PM
Sweden
Don't these units run at .030 from the factory with a .020 gasket?
wap13
12:35 PM
Ga
I'd like to see how this works out for you if you dont mind sharing here.
I have a stock 462 that impresses the heck out of me but have been considering a BGD. Once my other one gets back from Randy I'll start to tinker with the stock one.
Bigmac
9:35 AM
I thought I saw something about interference when deleting the base gasket on these … am I wrong???
Ed it sounds like the majority will interfere, the op has one with excessive squish from the start! I am guessing the base gasket is .015 like the 661. Stihl’s factory squish can be all over the board, I have a stock 660 that has .019 squish with gasket, also have an odd ms260 that had excessive squish and I could do a base gasket delete, the ms260 is not supposed to be able to bgd either. Ms 461 I have seen about.007 difference in several jugs and 660 have seen .016 different between different factory jugs.
So always measure! Lol
TX_Welder
11:35 AM
SE Texas
So I misremembered on my squish. squish was .033 gasket was .015 leaving .018 for head room. Is that okay for clearance or should I massage it to .020 ?
TX_Welder
11:35 AM
SE Texas
Saw has a lot of carbon build up for suposedly being a low hour machine. Supposed to have had around five tanks through it. I'm second owner and I've put about two tanks through it running stihl ultra doing some clearing work.
Bigmac
9:35 AM
.018 is my max tight on the cc class if your properly measured the squish, not a knock, you need to roll the motor multiple times and measure at the wrist pin it looks like you checked above the exhaust? If you decarbon everything it will change too
TX_Welder
11:35 AM
SE Texas
@Bigmac Yeah that's what I was thinking. By the time I clean everything up I'll probably get my .002 back. I did check above the exhaust, I see what you're saying. It hadn't occurred to me to check over the wrist pin. I'll clean it all up torque it down and recheck.
Bigmac
9:35 AM
Ya do that, the piston rocks when you check above the exhaust or intake and give a false reading, I had a 461 the would turn over with a base gasket delete because of carbon build up, de-carbon the chamber and .016 squish, sanded out .002 from the chamber with an old piston and stick on sandpaper
Bigmac
9:35 AM
.018 is plenty, that’s what my 066 was stock.
I do know of numerous 120cc work saws built with .015 and never an issue.
stihl ultra is not your friend
So what’s your max on a 70cc saw?
