MS280 Weak Spark
bark
10:36 AM
Hinckley IL
Ms 280 that has been flawless for years,now has weak spark.
I have tried a new coil which made it run for a few months then same problem again.
I tried 2 other coils and a different flywheel with no luck. Is there something simple that I am missing with this particular saw?
Is there a way to test the coil with a multimeter?
Wood Doctor
Edwin
10:36 AM
Omaha, Nebraska
Make certain your coil is grounded good to the chassis and check your on/off switch and stop wire with an ohm meter for a short.
Agreed. This saw has been around for awhile. Clean the whole area around the coil but good. I have even run into insect nests that messed up the connections and shorted out the spark. Grime is even worse. As need be, use a pipe stem cleaner and mixed fuel along with a toothbrush. Double check all connections to the ignition module.
bark
10:36 AM
Hinckley IL
Thanks guys. I will try these hopefully tomorrow and report back.
bark
10:36 AM
Hinckley IL
I Finally got a chance to look at this saw again. After cleaning it up as recommended it seems to have intermittent spark. Does the original flywheel have 2 sets of magnets on it? The flywheel that I have with this saw only has 1 set of magnets on it. It is probably very hard to tell in this picture but there are only magnets on the left side of the picture.
10:36 AM
Just one set like you are seeing
DrewUth
Too weird to live, too rare to die.
11:36 AM
SJ
I think the replacement of the coil that made it run fine for a few months is worth noting. If you have a bad ground somewhere, it could be prematurely wearing out components.
