Forallhesgot
Active OPE Member
Hi All,
I'll admit I'm not an expert - but I'm a bit stumped here, that's why I am asking the experts!
I bought an MS660 recently - the saw is in pretty good shape, ran well, cut well etc. when I tested. When I got home I pulled the muffler to inspect the cylinder and found a little wear on the exhaust side. Nothing too concerning, but I was up for a project - so I decided to pull the cylinder, clean it up and install a new meteor piston + rings.
Now when I first bought the saw it did run well, just felt like it may be a tiny bit low on compression as it was easy to start.
I cleaned up the OEM cylinder with scotchbrite, it cleaned up very well. There was a lot of carbon build up, on the head and exhaust. At the same time, I gutted the muffler and matched the exhaust outlet with the gasket and muffler. I installed a new OEM fuel filter, new Maxflow filter.
After the rebuild, I pressure + Vacuum tested the saw, checked the fuel lines, carb, fuel vent, impulse line. I checked a few times on all parts - it holds pressure and vacuum very well.
After the rebuild I ran it only with Stihl pre-mixed non e gas, to eliminate that variable - I ran almost 2 tanks though it and decided to pull the muffler + plug to see what was going on. It should be said that the saw ran great, the only issue is the idle would vary from a little low to a little higher after cutting, not sure if this is my tuning, or I;jm being overly sensitive but it would idle without stalling and ran well with lots of cutting power etc.
So when I pulled the plug and muffler I did find some marking, although very light it was concerning. Here are the pics after I pulled the cylinder (this is after the original rebuild + new piston)
These marks came out with a little hand sanding and scotch-brite - cleaned up very well with the exception of a tiny vertical scratch, this is mainly on the exhaust side (just like the OEM piston). Cant catch my fingernail on anything.
So I decided to run another tank through it, I pulled the plug to peer into the cylinder and I'm seeing very similar markings on the cylinder walls after 1 tank.
Now I have pressure + vacuum tested all parts of the saw several times, to try and eliminate that. the carb was cleaned and tested as well.
The bearings feel very good, no play and smooth. I also looked at them best I could with the cylinder off and they appear fine.. I cleaned out the case the best I could and also tried my best to have a clean working environment.
Now I'm a little stumped here.. The saw runs very well, I can't find any issues when running it with the exception of the idle being sometimes a little high or a little low after being on full throttle. The saw is tuned rich - its 4stroking a bit and I'm paying very close attention, doesn't seem to be leaning out in the cut or in high rpms. I'm also monitoring via a tach, but listening intently as well.
Any ideas?? I've searched high and low, can't seem to find any clear ideas.. Of course bearings jump out at me as a possible one, but can they be shot with no other obvious signs? Also after I took the saw apart the second time, I didn't see any obvious pieces of metal shavings (would there be a lot, or just a tiny bit?).
Here is looking through the spark plug hole now at the cylinder (this is after approx. 1 more tank, since second cylinder cleanup). The new piston still looks good, can't see hardly anything different on it.
I know its hard to see, but there are lines in there, I don't think they are deep (they cleaned up easily the first time)
I did not pull the clutch or flywheel off to check the bearings + seals, because they felt tight + smooth, when I flushed out the crankcase, I didn't see a lot of gunk or anything like that.
Of course the is my first expensive saw, so I want to get this work right and not ruin my purchase! I'm also a bit bummed that my first rebuild went this way, but sometimes that's the way she goes.. I would continue running and hope for the best, but I don't want to ruin anymore good OEM parts! Also this saw will pretty much be for milling, so I want to make sure its tip-top before I put it to use. For now I have just been running it for regular cutting to break in before it will go on the mill
Thanks in advance for your help, sorry for the novel haha!
