Ms 360 issue
trooney
Admitted Woodaholic
1:33 AM
The land of pleasant living
I have this 360 that has running issues when you start it up and it's cold. It bogs when the trigger is pulled until you get the chain to spin, about 15 seconds later, then it revs and runs fine. Idles fine to. Passed a pressure and vac test. Meteor cylinder and piston and a AM fuel line. Didn't pull the carb to inspect diaphrams, but what do you guys think? A couple of things running through my mind.
trooney
Admitted Woodaholic
1:33 AM
Yeah, that's one of my options. I'm with you, it' not the fuel line but it needs an upgrade.
Lightning Performance
1:33 AM
East of Philly
Same deal on my oe ms362. Squish @12, ign bump and muff mod. Cold blooded saw. Dies first twenty seconds you touch that throttle. Fresh piston and cabers. Tunes is great. Run it high and hard. I gave up.
I always make sure my acc pumps work or plug them off.
My 048 acts just like it.
trooney
Admitted Woodaholic
1:33 AM
Thanks guys. I just didn' want to think that I was going crazy. I think I'll just leave it alone. It looks like a new saw, still has the sticker on the front. It hasn' been used alot that's for sure.
1:33 AM
Maybe give it a tad more fuel on L and see if that helps a bit
