FOUND IT Mcculloch titan 620 crank seals
Mathewsdxt75
Learning OPE member.
11:53 PM
wisconsin
I am in need of crank seal for a mcculloch titan 620. Part# 227499. And possibly a oil gear and spacer. Numbers... 227388 and 227387
Any help is appreciated.
beaglebriar
The Peanut Gallery
12:53 AM
Warren Center, PA
If you have the old seals they usually have the size molded into them. Or you can measure with calipers. If you don't have a local bearing supplier you can do a search for whatever numbers are on the seal. If you still need help send me the info from your seals and I will check with my local bearing house.
Mathewsdxt75
11:53 PM
wisconsin
the local bearing company had what I needed!!
