- 5:07 PM
- Nov 2, 2019
- North Idaho
edited: Got another mac I'd like to sell. I had started messing with this 610 about 2 or 3 years back and gave it a cleaning but shelved it for some higher priority saws. If memory serves correctly I had put a kit in the carb and cleaned out the fuel tank. Although I put on a new oil pump gasket and diaphragm it still doesn't work. The oil pump itself probably needs to be replaced. I had it running and cut with it a little. However it never wanted to idle correctly. The piston looks good and there aren't any air leaks so the carb probably either needs to be worked on a little more or replaced. The spike that's on it is new. I replaced a couple chain brake components at one point so the brake works.
I've decided to essentially give this away. The first person to throw out a dollar amount takes it. I know i'm losing money on it but I don't care, I want it out of my shop. Of course you'll have to pay for shipping but I can get discounts so it should be reasonable.
Sent from my SM-N970U using Tapatalk
