Mastermind Revisits The MS261CM Type II
6:30 AM
This is the quote Jeremy, it does not say it remembers your last setttings, it says it remembers them under the "same external conditions". There would be legal liability if they said that and did not do it.
STIHL M-Tronic remembers your last setting under the same external conditions and resets to it every time once the engine reaches full power. "
EvilRoySlade
What’s my line?
6:30 AM
Michigan
You guys are funny. You're having a friendly argument that to me sounds like this;
Neopolitin ice cream is good because of the vanilla ice cream. No it's the chocolate that gives it the great flavor. I disagree, the strawberry really rounds out the combination of the other two. No guys, when you make a banana split, that's really where the three flavors shine.
6:30 AM
Well I'm glad someone understands it!!!
GCJenks204
"Special Buns"
5:30 AM
Winnipeg, MB
Is there any better answer than Ice Cream ?
EvilRoySlade
What’s my line?
6:30 AM
Michigan
I do not know how MT works but what I do know is it's an open loop system that uses programming to adjust jetting and possibly timing from what I understand to make the saw run in a range that engineers deem desirable.
Now, having higher velocity through the Venturi will create more vacuum which will help deliver fuel and atomize it better. This comes as a reward of the divider. The saw still runs so the same amount of fuel is being delivered as it would without the divider in theory. The quality of delivery (higher DP) and ultimately atomization as it leaves the jet in a ultra fine mist can (again in theory) allow the use of less fuel to get to stoichiometric.
Think of high pressure fuel injectors, it's not always about volume. It's more about using vapor pressure to your advantage.
