m5x1.25?
Backstage
OPE Member
1:25 AM
Michigan
Hi All,
First time poster. I’m trying to repair a stripped hand guard screw on a Husqvanra 455. For reference, that’s their part# 537296501. The plastic crankcase screw hole is stripped out and won’t hold the screw securely. I had thought to buy brass hot melt insert or make an insert on the lathe with a tap, but it’s apparently not an available size. Anywhere. And I buy oddball threading tools fairly regularly.
Any ideas on how to do this repair appreciated…
1:25 AM
Melt weed trimmer line into the hole and make sure it’s attached to the sides of the hole. Redrill to a size that works for your screw
67L36Driver
12:25 AM
Tip:
On a Still AV mount hole in the tank it’s possible to install a 5 x .8 Helicoil and just use a machine screw. The plastic is tuff !
