OnlyStihl
My Stihl ms261 has been leaking for a few years. Initially not much and didn't think it enough to bother with. Lately it is leaking to the point where I would like to fix it. Yesterday, I took the saw apart enough to clean and inspect the oil pump, and filled it and left it overnight. I now see that it is leaking from the screw oil adjustment.
Anybody know what is involved in fixing a leak at the screw adjustment? The setting was full oiling, so I back it off to minimum oil output to see if that is a minimal fix. I figure I'd let it rest there and will open it back up when cutting, and close it off between cutting firewood. If that fixes it, then fine, but if not, it seems it would be a rather involved to tear into the saw and fix the leak.
