Jonsred 2166 build
BuxtonSaws
1:59 PM
Wisconsin
Not a saw I build often. Due to the piston weight. But I decided to do one for a local customer.
BuxtonSaws
1:59 PM
Wisconsin
A few in process photos. I actually did not cut any off the base of this saw. With out a gasket it was sitting at .015.. all I did machine wise was take .006 out of the band.
BuxtonSaws
1:59 PM
Wisconsin
If you notice I open up the transfers a good bit on these.. I also remove the devider out of the cover. These are some photos of it a little more towards the end. Exhaust is polished and ports are beveled.
BuxtonSaws
1:59 PM
Wisconsin
I will include some photos of the muffler and a video of this one in wood later this weekend.. stay tuned .. btw final port timing is 99 117 77 I did have to remove a little off the bottom of the intake to get the 77 it was sitting around 75.. I typically do not touch intakes on strato saws. I could of avoided doing so with a little more machine work. But I do not want this one to be real high on compression with the bearing issues.
BuxtonSaws
1:59 PM
Wisconsin
Just a shot of the transfer covers.
Ronie
2:59 PM
NC
Did you widen the intake? I think on the one I did could only barely be widened at the floor because it would get into the piston cutout.
BuxtonSaws
1:59 PM
Wisconsin
Paint is dry on the muffler.. this one got a nice healthy top port. Brazed on deflector stamped by Joe. When putting that much heat around plastics always protect them. It never hurts to add some muffler tape
BuxtonSaws
1:59 PM
Wisconsin
Sounds good. When done right an XT will hang right with the famed OE 372/2171.
Thanks its definitely a runner. I still think I get more out of the non xt. But I have not done a ton of xt saws and done tons of xp....This one is definitely close. I dig it and definitely will be doing more now.
