WANTED jonsereds 910 loop handle
burnses
Active OPE Member
8:58 AM
ma
looking for a loop handle for a 910 jonsereds and a source for crankcase gasket and crank seals...thanks
beaglebriar
The Peanut Gallery
8:58 AM
Warren Center, PA
I'm not following "loop handle" can you explain? Case gasket and seals are NLA. If the seals are the same as the 920/930 I have a set here that will work for you. For the case gasket go to the auto parts store and grab some gasket paper around the same thickness. .030 is what I've used.
I spread some 518 on one case half and press it down firmly on a flat surface. Then cut it out. It ain't perfect but it works best of anything I've tried.
burnses
Active OPE Member
8:58 AM
ma
yup front handle...
thanks
beaglebriar
The Peanut Gallery
8:58 AM
Warren Center, PA
I might have one if its the same as 920/930?? But I think they may be different.
2stroker
8:58 AM
NE Ohio
A couple things. I've got several older J-red handles but the part numbers are rubbed off. Can you send me some dimensions so I can verify the fit? End to bol
Is the case split? If so traced the outline of set it on a copy machine and send me the print. I have a selection of case gaskets but no parts numbers to go with them. They aren't 2094 or 2095 as I have gaskets for those also.
Regards,
2stroler
beaglebriar
The Peanut Gallery
8:58 AM
Warren Center, PA
Looks like the seals I have will work send me a PM if interested.
Frank bierce
5:58 AM
I’m pretty sure this is a NOS 1/2 wrap for a 910...
