SOLD Jonsereds 110...
bulletpruf
7:07 PM
San Antonio, TX
Ok, those of you who collect Jonsereds know these are rare as rocking horse poo. After years of looking, I've only seen 4 or 5 posted online. I'm sure there are more out there, but you'd definitely be the only one on your block with one.
The 110 is the predecessor to the 111, which was followed by the 111S. As best as I can tell, the 110 was a one year only saw, produced in 1972. It was followed by the 111 in 1973, and the 111S came out in 1974. It's different than the 111S in a few different respects -- it has needle crank bearings, not roller bearings, and the OD is a good bit smaller, so the cases are different. The oiler has a slightly different configuration, the decomp is different, ignition configured differently, and the 110 has a poly flywheel instead of aluminum.
I found this particular saw in Sweden years ago, and finally got around to giving it the full rebuild that it deserves. Although I had nicer components to put on it, I went with all original items (all exterior parts, jug, piston, etc) with one exception -- a top cover from another saw. The original, which will be included as well, has a few broken mounting tabs.
Anyway, I split the case, installed new crank seals, gave it a thorough cleaning and inspection, rebuilt the carburetor, went through the ignition, opened up the fuel and oil tank and cleaned it out, giving the fuel tank a coat of Red-Kote to seal it up good. The saw is in very good condition, muffler is un-dented and solid, no broken tabs on the top cover, no stripped bolt holes anywhere, compression is great at 193 psi(!), and it comes with your choice of bars - a 36" Jonsereds hard nose or a 36" Oregon roller tip. It's set up to run 3/8 chain, and has a rim drive sprocket.
It starts easily, revs great, idles at 2,200 and tops out at 11,500 at WOT, unloaded, four stroking. Will clean up in the cut.
I am in San Antonio, Texas but I will ship worldwide. I will also consider trades for the following: Jonsereds XA diesel, Stihl Contra G or GS, or Solo Twin. Trades of other saws (Stihl 090, 090G?) + cash considered, too.
Hard to put a value on these. I'd like to get $2,500 for it, but the price is negotiable.
2188redhead
Active OPE Member
1:07 PM
Hudson,WI
bulletpruf
7:07 PM
San Antonio, TX
David - I'd take $2k + shipping for it, but if he wants it, please tell him to contact me ASAP. Otherwise, I have someone who wants to trade a Jonsereds XA diesel for it. I would trade for $2k worth of saws that are easily converted to green stuff -- 084, 066, 056 Mag, 090, 090G, etc.
EDIT: If he's on a budget, he'd probably be better off buying some of my other Jonsereds - 60, 601, 62, 621, 80, 90, XG, XF.
2188redhead
Active OPE Member
1:07 PM
Hudson,WI
Ok I'll call him,what's that jred xa worth anyhow
bulletpruf
7:07 PM
San Antonio, TX
XA is roughly equivalent to a 110, but a 110 is rarer in Europe than it is here, and the XA is rarer here than it is in Europe.
Hard to be more specific than that since these saws rarely trade hands on the open market.
2188redhead
Active OPE Member
1:07 PM
Hudson,WI
He said he would think on a trade for u,he mentioned a gold ring he won racing,said it was worth 2200 in the 80's I said it's probably work 8 k now..I'd hope he would never consider that,but anyhow I'll have to get back to u on this,after I hear back from him..I appreciate it
2188redhead
Active OPE Member
1:07 PM
Hudson,WI
I'll let him know on the others,I brought him down a really nice 601 from original owner and a letter from tilton co to him containg the parts list..
2188redhead
Active OPE Member
1:07 PM
Hudson,WI
Would u pm me a list of older jreds u want to sell,he likes Red!!
bulletpruf
7:07 PM
San Antonio, TX
This one is on the way to Yurrup...some feller is trading me some sort of old diesel Johnny Red for my gas saw...if'n it runs like my old 7.3 I should be able to cut a bunch of wood with it...
