Johnmn
- 7:59 PM
- Feb 18, 2016
- Minnesota
Jonsered 670 with OEM Husqvarna 272 cylinder. Split the cases and did bearings, gaskets, seals, meteor piston, carb kit, fuel line and filter. Full wrap with OEM v-stack, timing advance, base delete. Cylinder has a broken fin, I can get picture if needed. 2 piece coil.
Cylinder had bad timing numbers so I raised the transfers with a cut off wheel and raised the exhaust. Intake untouched.
Timing numbers 102-120-74 squish .018
$300 plus shipping friends and family or add 3% bar options available
I thought I took a finished product picture but I guess not. Saw has 2 tanks on it since rebuild.
