- 1:21 PM
- Mar 14, 2017
- Illinois
This is a Jonsered 2095 that has sat for awhile. I pulled it out tonight, put some fuel in the tank and it fired up with just a few pulls. I did not log test it but it seemed to run decent. The piston looks good through the exhaust and the compression is strong. As you can see the brake handle is broke off. There is no brake band in the cover either. Since it has sat awhile you might want to do the normal carb kit but as I said it fired right up tonight. I think $525 plus shipping is fair.
Note the pictures are horrible, I can take better ones if required.
