Jonsered 2094
stihl livin
Do the Dallas
7:44 AM
Upper Midwest
A friend of mine has a 2094 that I can use if ever needed. I'm not very familiar with the big jonsereds or huskies. Are these large mount saws that can be set up with an adapter to run a Stihl mount bar? How are they compared to the Stihl 066/660 saws? Any and all info appreciated.
stihl livin
Do the Dallas
7:44 AM
Upper Midwest
Nik, if you've ever ran a Husqvarna 394XP, then you've pretty much ran a 2094.
They are excellent saws, and yes, they use the large mount Husky bar.
I haven't run much other than small huskies or Jonsereds
cgraham1
5:44 AM
Nor Cal
Parts availability on the 2094/2095 saws really sucks. I had a 2095 and I couldn't even find a brake band for it.
cgraham1
5:44 AM
Nor Cal
It was the easiest starting saw I've ever owned. It would sometimes start on the first pull cold, and if I was quick, I could flip the choke off before it died.
cgraham1
5:44 AM
Nor Cal
I sold that saw for $400. That's a lot of saw for that money.
jacob j.
Only the weird
5:44 AM
Coastal Oregon
The bar studs on the 2094/2095 are closer together than the 394/395, so the Cannon bar adapter will not work without modification. Mike's (Homelite410) adapters will work though because he's already considered for the older Huskies/Jonsereds.
