HELP! Jonesred 2051 Turbo
Outback1
9:10 PM
California
I have just acquired a Jonesred 2051 Turbo saw and was wondering what size bar should be used and what is your thoughts on the saw?
AKJonsereds
12:10 AM
Anchorage
I have never run one but I believe it is a high revving pro saw. Watched for one to try for a long time but like 60cc for the stuff I do.
I like a 18” bar on saws that size but others around here would know the balance on that saw better.
Hillwilliam
10:10 PM
Del Norte, CO
I acquired one of those free a while back. Fixed a couple of things and fought with pesky air leaks for a while. Pretty snotty stock, but I ported mine conservatively, and it will turn 16 grand. Thought it might be able to handle a 24, but I changed my mind and it still has the 20 it came with. Nifty little saw.
Outback1
9:10 PM
California
Thank you for the information. I was thinking a 20” bar as well. I’m trying to figure out which saw in the Husqvarna line is a match so I can cross reference parts in needed?
Duce
12:10 AM
Roscommon, MI
Believe that is a 50cc saw and I would run an 18 on it. It also depends on type of wood and chain you are using.
Outback1
9:10 PM
California
Thank you for your information. I’m just trying to figure out the Husqvarna saw it shares parts with in case I need some replacements?
Outback1
9:10 PM
California
I’m into Oak, Doug Fur, sugar pine etc. I think it’s a small pin mount for a bar correct?
5155
12:10 AM
pa
18" .325 is what my husky 51s and 55s like. If closer I'd let you try my bar/chain.
Duce
12:10 AM
Roscommon, MI
Believe you will find there is no direct comparison.
Duce
12:10 AM
Roscommon, MI
I mainly cut red oak and 18 works very well on my mk2 550. I touch up my chains and keep my bar dressed, have seen many running a mess lately.
wcorey
12:10 AM
ma usa
Correct, there's a 2051, 2054 and 2055 in this 'family' and that's it. Unique little saws and quite good runners.
blackbruin
Heeeeeeere's Johnny!
12:10 AM
US
2051 is the "hotrod" of the bunch. .325 in 18 is good. 2054 had 2 versions. Epa and reg..epa has a decomp is more cc but less of a saw than the non decomp a 2051 or a 2055.
Great av basically a baby 2095. Case issues early. Flip the louvers to keep heat off front of case or add another outlet so heat goes away from case
Woodslasher
Teh debil
9:10 PM
Commiefornia
20" .325 bar in CA isn't a huge deal, keep a sharp chain and don't dawg it like it's 90cc's. I mostly prefer the 20 for reach when I'm limbing, fyi.
