KellyJackson
Need Husky 65L Parts/Saw
- 1:57 PM
- Jan 22, 2022
- Abbotsford ..
I have a Model 65 Husky TOMOS (Yugoslavian Manufactured) Saw as well as Several Swedish 65l & 0650 Model Saws. On Most of these Saws the Plastic Handle that Mounts the Throttle Trigger/Lever is Secured to the Rear of these Saw Bodies on the Top Part of the Handle Directly behind the Carb by 2 Metric Hex Head Bolts. These Bolts are held in Place and Hold the Upper Part of the Handle to the Rear of the Saw Body by way of Round Threaded Tube/Pipe which runs through three Seperate Plastic Parts on the Top of the Rear Handle. Most of the Saws, I Can remove or Push this Threaded Metal Tube Out Through the 3 Seperate Plastic Handle Parts but on the Tomos Mage Saw, For some Reason I Can Not Remove the Left Side Bolt from this Threaded Tube/Pipe which Hold the Top of the Handle. On all the Other Saws I can Push this Metal Threaded Tube/Pipe right Through the Plastic Handle Parts but on the Tomos Model it wont move & i Don't want to Break the Handle. am Currently Soaking the Top of the Handle in Penetrating Oil. Could anyb one tell me how to remove this Handle Correctly
