husqvarna fuel line sillyness
jake wells
no longer here
4:33 AM
ky
will bulk stihl fuel line work as a drop in my local dealer keeps jacking the price of the 9 inch piece of curly line for husq stuff.
lwhaples
5:33 AM
Vt
I'm also looking for a cheaper route.Echo line seems to be better in price than the Husky bags.
jake wells
no longer here
4:33 AM
ky
echo line it is price is better than the stihl line too.
Mattyo
Youtube speciawist
5:33 AM
Farmington, CT
I have not actually tried echo line in a saw yet, but even though there is some constriction where it enters the tank, it should still work.
Simondo
10:33 AM
UK
I use TYGON (yellow) fuel line in most situations that don't need a sealing grommet or captive stepped carb connection moulded on the line. I keep a range of sizes and its very !! cost effective plus you can custom fit to any length for better routing than some standard lines of a fixed size. Tygon works well against crushing in a tight bend plus dipped in hot water stretches over a tube easy if a little on the small side.
jake wells
no longer here
4:33 AM
ky
Tygon is 1.25 per ft in my area but I don't use it.
Mathewsdxt75
Learning OPE member.
4:33 AM
wisconsin
I have had very good luck with the echo fuel line. The dealer near my work has it. I have used the tygon a few times and it is just fine, but I am going to use tbe echo line when I can.
jake wells
no longer here
4:33 AM
ky
i got 6 ft yesterday for 1.38 per ft can't beat that i told him i want 25ft of it and he said you can want in one hand and crap in other and see which one fills up the fastest.
