livemusic
- 10:37 PM
- Jan 22, 2016
- NW Louisiana, USA
This combo can is awesome, very thick plastic, should be tough. It is very well engineered. Some youtubes show advantages. Has no spill spouts for gas and oil, onboard toolbox and transparent sight lines for viewing fuel and oil levels. First I couldn't figure out how to get into the toolbox, lol but a youtube guy happened to open it and I saw. Sheesh, I didn't want to tear it up getting into the toolbox, lol. (Don't life the knobby plastic part sticking out, there are two rubber tabs below that to lift.)
The gas and oil containers come with screw-on caps and a plastic retainer band to keep it on the threads when you unscrew it. What I did was I unscrewed the caps for both gas and oil and then stuck the cap through the handle, such that the plastic retainer band is keeping it secured to the threads. I then screwed the no-spill spouts onto the threads. Done like that you can still carry it by the top handle. Now, Husqvarna said in writing to transport it (travel) with the plain caps on, not the no-spill spouts. Maybe for safety/legal reasons. But if you do that, where are you going to put the no-spill spouts? If they had retainer bands, you could do what I did, sticking them thought the handle. Otherwise, you're going to have to store them elsewhere. Unless I'm missing some trick.
The no-spill spout that is gray goes on the oil side. I confirmed that when I note that it is marked as such via embossing on the spout. They also included another gray spout and it provides open flow, it is not no-spill. I think this is for extreme cold, when chain oil will not readily flow.
They should have included better and more thorough instructions or included a link to an online page. If that exists, I haven't found it.
If someone knows errors or improvements to the above, advise!
I got in less than two weeks from Europe. Good product, Husqvarna!
I got it from Amazon but available other places, too.
