Hey I've got one, number 123546. Metal bale chain brake. Nice looking cover and muffler not all beat. Ran good last time I used it (quite a while ago.) Stored with an empty tank. Still looking?
Fired right up with fuel. Runs a bit rough. 160# compression even with more than .050 squish. It has the more modern replacement carb that does not adjust from the outside.
Chain brake cover is missing a chip. Works.
Top cover is cracked.
Rancher.
Nice clean muffler though. So many are stove in worse.
I had converted several 61s to 272s with the 52mm aftermarket cylinders and they were super. Finally I guess I had done enough of them, so this one sat.
What kind of price are you thinking? I am currently building a 61 single coil and a 66 now with the orange top to 52mm. I just like the old white top 61 that will run with minor work.
