SOLD Husqvarna 55 CP
Trader history (1)
GoBigBlue1984
Bluegrass Fart Knocker...
10:04 AM
Kentucky
Selling a Husqvarna 55 closed port. All OEM. 45mm original top end. I have two of these, I hardly use either one and this one is nicer than the other....so it goes. Saw runs and oils as it should.
I’ve got a Spike60 like Husqvarna dealer locally. The guy is into saws thus he and I get along great. This saw came from him along with what must’ve been 20-30 51/55’s I’ve had over the years. This was one of the first I got from him when I was into the 51/55’s pretty heavy.
Clean saw that hasn’t been abused as pictures will show. Typical 51/55 brake flag burn spot. Op presence lever has been disabled (spring removed). Upper right corner of cylinder cover has been trimmed at 45 degree angle (Minor cosmetic defects)
Muffler has been split and baffle removed.
I put a brand new Zama carb on the saw when I got it.
$225 plus shipping from 42748
I’ll get video of it cutting this weekend.
Any questions just ask.
83841894-6D4A-4581-8CBE-EAC8F1BDE9BD.jpeg ADC89DAA-537C-4A3D-96A1-937EC8970B93.jpeg C7B0B588-7385-45BE-8DDD-B6A7A7155CE9.jpeg 583FB87E-CDC3-4D3C-8D6B-03CB960907A4.jpeg F0389492-21F4-4FD4-A1C5-53A596E5F29E.jpeg
GoBigBlue1984
10:04 AM
Kentucky
Yah but looks like we just lost our QB for the year :crybaby2:
5155
10:04 AM
pa
Does this come with it's original bar? ,325-.058-72dl
GoBigBlue1984
10:04 AM
Kentucky
It had a .325 setup on it, I’ve still got it. But I switched it over to 3/8 setup. I run 3/8 on everything. Convenient for me that way.
But I bought it pho, so no it doesn’t have the “original” bar.
GoBigBlue1984
10:04 AM
Kentucky
.050 squish with base gasket.
My el cheapo tester shows 130.
I’ll cut the base to set squish at .020 for the $225 plus shipping.
Or I’ll do $190 plus shipping. If it’s not worth that I’ll put it back on the shelf with the others.
5155
10:04 AM
pa
Cut the base as you said .020 with gasket, fresh piston ring and impulse grommet, fuel line, set it back to drive .325, and anything else while in it, I'll take it. If you need couple bucks for the above I can do that.
Oh and be sure that darn partition is good to go.
I might not get back on here today but will by tomorrow.
GoBigBlue1984
10:04 AM
Kentucky
Fuel line/fuel filter/partition were brand new when I got this saw from my husky dealer. It had been gone through by them. Of course I checked it over when I got it as well. I had a brand new carb for it, so I went ahead and put it on. I’ve got new cabers for these as well. I’ll swap one in.
