WANTED Husqvarna 395 Flywheel
Trader history (1)
srcarr52
11:13 PM
Iowa City
Looking for a 395 flywheel with starter paws, I'll take a carcass if it's still attached. Thanks!
Wagnerwerks
11:13 PM
Pa
Are they the same as a 288?
srcarr52
11:13 PM
Iowa City
Bump, still looking.
jacob j.
Only the weird
8:13 PM
Coastal Oregon
I rooted through some stuff last night and night before, with no luck. I have a couple more boxes to look through tonight.
I have lots of 394 cranks and flywheels though, if you want to go that route.
srcarr52
11:13 PM
Iowa City
Unfortunately this is a modified longer stroke crank that I already made to fit a 395 flywheel thinking I had one. So I'd have to cut another crank and disassemble that case to go that route. :(
Moparmyway
Its just a saw
11:13 PM
In a meeting
Couldnt you use a 394 flywheel and run it without a key
or
modify the seperate key from the 394 to work with the 395 crank if the magnets are timed the same ?
(I believe they are, but havent checked to be sure)
srcarr52
11:13 PM
Iowa City
or
The taper and size of the crank snout between the 394 and 395 are different. The 395 is the smaller snout of the two.
jacob j.
Only the weird
8:13 PM
Coastal Oregon
I figured it was something like that. I wonder if a person could use a 385 flywheel? The taper is the same but the overall diameter is just slightly less and the timing is a bit different as the coil location between the two saws is slightly different.
