Husqvarna 394 case repairs, welding.
srcarr52
10:38 PM
Iowa City
might add that "cleaning" w/fiber grinder wheels leaves chit embedded in base metal, contaminating weld.
carbide burrs/die grinder is cleaner. or wire brush...
my rate is $50./hr., btw.
Plus a dedicated stainless steel wire brush. If you brush steel then aluminum or magnesium it will embed microscopic bits of rust and steel into the material.
angelo c
Coal Member
10:38 PM
There are really only two rod alloys readily available. AZ92A and AZ61A, on dirty old cases I can’t really tell the difference.
You set the tig welder on AC with setting similar to welding aluminum. Cleaning and prep is everything.
does pre-heat make a difference ? like with thicker Al ?
and thanks btw.
beaglebriar
The Peanut Gallery
10:38 PM
Warren Center, PA
Beautiful work as always.
I have a busted up set here that I need to send you.
kanscruzer
9:38 PM
kansas city
Stainless steel wire brush. only used on stainless
srcarr52
10:38 PM
Iowa City
