SOLD Husqvarna 372xp rebuild
Duce
11:54 PM
Roscommon, MI
Here is a list of what was used in rebuild. Used OEM crank (tight lower rod bearing), case, flywheel, unlimited coil, muffler (stock port enlarged), oil pump, K-saw fuel tank. SKF case crank bearings. New Hyway piston and cylinder ($99) with Caber rings. Some AM plastic and new zama carb with name removed (Farmtec)IMG_7437.JPG IMG_7440.JPG IMG_7441.JPG IMG_7442.JPG IMG_7437.JPG IMG_7440.JPG IMG_7441.JPG IMG_7442.JPG IMG_7434.JPG . Motoseal used for base gasket delete. For those Husqvarna loose screw haters, blue locktite. This should make a nice firewood saw. Idles at 2800 over-run was set at 12,500 on my tach at 1200 ft. Vacuum tested for leaks (none). PHO shipped to lower 48 states $325.
Crzybowhntr
Apprentice Slacker
11:54 PM
WV
Geeze. That took a long time. ;)
cus_deluxe
terms of service violator
11:54 PM
Michigan
Did i see this one on mi craiglist?
