- 2:27 PM
- Oct 21, 2016
- Kansas
His vids are better than viagra .
Fixed for accuracy.
If Viagra makes you comatose.Fixed for accuracy.
Jeff,Hooskies burn my hands when I touch them. I just can't run them.
@RI Chevy if the clamshell setup on your 345 or whatever it is you have is like the 350 w/ the riser plate it's really no big deal to pull the cylinder to go to a metal clamp. Carb comes off easy, 4 bolts pull cylinder, remove boot, install new clamp setup, consider ditching base gasket and use sealer install cylinder / boot. Install carb and you are off.
340 and 345 dont have the riser.
Ouch -- thanks for the clarification. Did a very successful topend changeout on a 346 so I'm find w/ pulling the jug on 350 to do the boot and clamp.
You can buy the riser dirt cheap.
