SOLD Husqvarna 3120 crankshaft
GeorgiaVOL
2:48 AM
Columbus GA
I have a used OEM 3120 crank if someone needs one. $75 plus shipping. Thanks!
mortalitool
aka Nick Stoeckel
2:48 AM
Lexington, MN
Do you have any more pictures?
Did it come out of a chainsaw or a chopper?
jacob j.
Only the weird
11:48 PM
Coastal Oregon
I think the chainsaw and demolition saw cranks are the same, except for some of the demolition saw
cranks have a hole in the PTO stub shaft to allow excess oil from the crankcase to seep through to the
bearing for the drive drum (i.e. clutch drum).
I have two cranks here, one from a chainsaw, and one from a demo - both have the same part numbers
on the lobe but one has the hole and the other doesn't.
jockeydeuce
11:48 PM
BC, Canada
They must have used those cranks in a few chainaws too....I had a customers basically new (2017) 3120 here that was failing pressure test....It was leaking out the lube feed hole to the drum brg.
jacob j.
Only the weird
11:48 PM
Coastal Oregon
I think so Rob - I tore down a 2006 chainsaw and it had one of those cranks...I couldn't get it to hold a tune after the complete rebuild.
It was very frustrating until I traced back where the hole came from. I plugged it with Yamabond and life was good after that.
jockeydeuce
11:48 PM
BC, Canada
Did you just fill the hole up out at the drum end?....I may revisit that saw next time it's in...it never held a consistent tune either. I understand they are supposed to have more or less a duckbill valve in the crank that allows pressure out to lube the bearing, but not allow vacuum in. I don't think they work half the time.
jacob j.
Only the weird
11:48 PM
Coastal Oregon
I plugged it at the hole under the drum yes - I ground down a tuning screwdriver to a very narrow point so I could work in the Yamabond quite
a ways...and then I let it cure for 36 hours before I put the saw in service. I had the saw out for three days in the woods testing, and then it was
traded to a member here.
It's one of those "undocumented" production line changes that Husqvarna is famous for...
